Hello ,
Looking for some help with my 1992 492 New Holland Haybine. The top roller has a knocking noise in it and I m trying to determine what is causing it. When the PTO is engaged and tractor is running at slow idle the top roller knocks if you kill the tractor and with your hand move the top roller quickly forward it knocks also when I turn the roller by using the top drive shaft it will knock. The knocking seems to be louder or more located at the end of the roller where the tension crank is but not sure if the noise is just traveling to that end. The Rollers are not in bad shape still have all the rubber on them. Any help or feed back would be much appreciated.
Thanks,
3020
Thanks,
3020
