DonB
- Location
- Manhattan,Kansas
I have cleaned them with paint brush and gasoline
https://partscatalog.deere.com/jdrc...JT04sNDc5ODojQ0FUQUxPRyw2MjkyNTpFUVVJUE1FTlRdI can't find a clutch bearing. Steiner and all them have a clutch pilot bearing but it says it's used for the outer power steering pump bearing. The pulley has a missing bushing, we're addressing that. But inside there's a bearing with a bunch of rollers. This bearing has a bunch of room to slide on the shaft at least the way it is right now off the tractor. There's a race still stuck on the shaft on the tractor. The outer race is just a seal and it's all bent in. Called steiner and they said have to call a John Deere dealer. Went to Deere's parts catalogue and put in the tractor's serial number and it came up with no results. I thought Deere still sold parts for these tractors?
Not sure where you were on JD Parts site, but I have never been prompted to enter a serial number to search for parts.Went to Deere's parts catalogue and put in the tractor's serial number and it came up with no results. I thought Deere still sold parts for these tractors?
For certain newer equipment or engines you can search by S.N., that doesn't work with old things that use the scanned/.pdf parts catalogs.Not sure where you were on JD Parts site, but I have never been prompted to enter a serial number to search for parts.
Are you saying to move the lever forward and back while looscening the nuts until it makes the snap they demonstrate on Youtube? I imagine if they were snug like that, it wouldn't be able to release at all? Do you tighten them with the lever engaged or disengaged?When I went through and rebuilt our 630 it is easier to just replace all of the wear parts. It makes setting the clutch much easier. One other thing is check the dogs on the clutch most of them end up snapping. Usually there is a small crack in them and it gets larger with time. When you go to set the clutch I found it easier to tighten the nuts down snug and then back them off until you get the snap.
It's not entirely a bad thing to replace all the discs. There's been lots of cases where one of the discs breaks and folds over and locks up the clutch. This happens mainly if someone parks the tractor while running with the clutch disengaged. And if it's still in gear when the clutch locks up things turn ugly pretty fast....thanks I'm good to go, bought all facings and springs and the pressure plate washer things. Also the brake liner. Bushing too, but decided to hold off on the bearing for now, can't locate the inner race. Got the outer race and the retainer tracked down. I updated another thread in this forum for others looking for cross-reference numbers.
I didn't do dogs and t's because they look and feel in great shape. The pulley has obviously been off before since the bushing was missing, so in theory someone has already possibly done that.
Sort of regretting buying all the facings. I should have just bought the one that's hard to get to and then picked whichever of the old floating facings is in the best shape and put it back together. If it still had issues, could easily replace the other facings.
Wow, I hadn't thought of that. But now I have started worrying about the little pin on the back. Mine has a deep notch in it, not quite halfway through it. I didn't bother buying it because I didn't understand how it's installed or removed, and the new ones all say you have to drill the hole bigger. But if that breaks off it'll be a bad day right?It's not entirely a bad thing to replace all the discs. There's been lots of cases where one of the discs breaks and folds over and locks up the clutch. This happens mainly if someone parks the tractor while running with the clutch disengaged. And if it's still in gear when the clutch locks up things turn ugly pretty fast....
After looking again at the pin, decided it was a good idea not to replace it, it's not nearly halfway through it. Everything arrived today. The clutch disk with the bonded facings on it is really rough textured. The two floating facings are smoother but have grooves on one side. Which way do the grooves go? The old ones don't have that.Wow, I hadn't thought of that. But now I have started worrying about the little pin on the back. Mine has a deep notch in it, not quite halfway through it. I didn't bother buying it because I didn't understand how it's installed or removed, and the new ones all say you have to drill the hole bigger. But if that breaks off it'll be a bad day right?
Grooves make no difference they can be installed either way.After looking again at the pin, decided it was a good idea not to replace it, it's not nearly halfway through it. Everything arrived today. The clutch disk with the bonded facings on it is really rough textured. The two floating facings are smoother but have grooves on one side. Which way do the grooves go? The old ones don't have that.
I think the next step is to tackle this. To clarify, it leaks out the end, right where the hose will go. We're thinking of draining and filling the hydraulic tank with the same stuff we use on the farm and then take the hose from one of our implements and plug and unplug it a few times and hope that seats the little pin valve thing.Wet lines I assume are hydraulic lines. There are square profile rings at each end that are easy to replace if they are leaking.
The question first is, where do you drain the hydraulic? We found a slightly smaller bolt head on the bottom, near the back, just left of the drawbar and just in front of the lower bracket the drawbar slides left and right on. Is that it?
If I remember right, the other two are bigger, but the same size as each other, and both are for the transmission fluid.
For filling, it's the one right below the seat that's angled upward slightly and has a dipstick on it, right? For some reason, our manuals aren't making it super clear.
After we do that, if jabbing a hydraulic hose into it doesn't seat it, what should we try next?
This discussion is for the auxiliary wet line coupler's for running cylinders and such on drawn equipment. We're good all the way to the actual couplers, just one coupler is leaking fluid out of it when the power troll pump is turned on. Like if we were going to run the round baler on this tractor, we need to connect the hoses to run the tail gate so we can let the bale fall out. One of the quick disconnect fittings is leaking right out the end the hose would go in. there's a ball back in there that must not be seating properly when there's no hose in it. We want to fix that problem. We've been leaving the pump out of gear as a result of the leak, but that means nonfunctioning lift arms.Are you talking the hydraulic lines going into the hydraulic pump under the hood?? I hope you can get lucky with removing them because mine were a @#$! to get out.
Which manual do you have?? The original JD om explains the oil drain plugs pretty good.
What are you jabbing a hydraulic hose into to seat??
