Hey guys,
This is my second season haying. Currently running older equipment but i make it work. I am in the pacific northwest.
Have a particular question about how hay is pulled or run threw rollers on a haybine conditioner.
Ill explain backstory for info first. Running a MF 255 50hp tractor with a NH 492 swather. I seeded a heavy crop of 4 varities of grass, 30% Orchard grass, 30% fescue, 25% Brome, 15% Timothy. Very tight seeding, grows well, but thick and tight not much airflow. I Irrigate with a pivot in the okanagan a hot dry desert like climate most of the summer with rich soil. I can hammer down 1" of water every 2 days and because I can I do.My crops end up being average 2+ ton for all three cuts with first being the heaviest.
When it comes to cutting doesnt matter how long i left the water off 7 day - 10 days, the stems are so thick that the bottom 4-12 inches never totally dries out, always remaining a bit moist. wind cant penetrate and the sun does not get threw. My Soil is dry.
All cuts do the following but especially bad on this one leading to third cut here now the ole 492 is struggling to clean material threw it once it cuts, being September shorter days and not as hot with 100% humidity nightly lots of dew. Cuts well although my cutterbar does need attention. What happens is the wet lower sections lays on the flat face below the rollers and then the material starts building up there. Eventually it gets rolling around into a ball and bangs super loudly threw my rollers, sometimes getting so bad that the mower starts to shake the tractor where i stop pick up then it clears threw the rollers with an aggressive banging.
I read the NH 492 manual and my crop being 3 feet+ long when i cut it is bent over halfway, kind of tangled from the wind the suggestion is move the tine reel forward and down. I lowered the reel as much as possible and moved it forwards. Im forward about 80% on the reel tine and that is just barely clearing the knife gaurds and have no spacers under the reel tine mount anymore (had 4 previously).
Its a bit better with this setting but still clumping up. I would have thought closer to the angled edge leading up to the rollers would be better to clean grass off of it. but i dont have the experience
I run the tractor at full pto speed if not better and im in Low 1 clutching frequently to slow down which is 1.4 MPH or slower with clutch.
The agressive banging on the rolls im not sure why it is so bad as i have the rubber spacers on both sides still. I dont know how to add more, like get pressure off the spacer from the roller tension bracket to add or remove more spacers. manual doesnt get into this. I also dont know how to tighten up the rollers to make them closer together as all i have is the rubber spacer and thats it.
I do have some gap in between the rolls i would say close to 1/4" and my lower driveshaft is pretty worn allowing the roller to have play and hit the upper roller which its driveshaft has a tiny bit of play in the square drive but not nearly as much as the lower with the hex drive.
Any advise for guys who have running haybines in thick grass?
Will tightening my roll gap and having them in time better (ie no play in the driveshafts) allow the material to flow threw better?
My rolls are in decent shape for how old the machine is not chunking a bit of cracking but not major and rubber is not deteriorating yet. the corners of the rubber crimpers are a bit rounded.
I picked up a MF 275 tractor last week with 67 PTO HP but it will need some TLC this winter before i can use it. I was thinking of trying to get a 9' discbine with conditioner rolls i think hesston and case make a 9' with 65hp minimum rating. I know this would not be ideal but if i can go 3mph instead of 1mph that will be a win in my books.
The struggle is i can get the grass down with the 492 it takes a long time but it gets down. Once its down every 20 feet i have a super large pile. Now when it comes to drying this pile never totally dries out doesnt matter how many times i rake it. When i hit it with the rake or turner the pile almost balls up and becomes bigger not rolling off the rake nicely its so big. If i wait until the balls are dry 7+ days ill lose way to much moisture and tonnage from the rest of the windrows.
Then i get wet green flakes in my small squares. trying to eliminate that.
Thanks for any help and experience, i didnt grow up farming and trying to get into it and want to put up premium feed. But have no experience to help me.
