gwayne1962
My Farmall 560 was locked in gear. I need to improve the movement on my clutch and TA. Anytime I am under pressure the gears lock up and at times have to take the shifter off and use a wrench to align the gears back.
In doing so the other day, I was using another wrench as a filler and when the gear moved, the wrench fell into the hole and is now somewhere in the bottom of that tank. I have tried to magnet the wrench out...but have no luck...cannot see anything thru the little hole where shifter was removed.
Is there any other plate i can take off to get to the bottom of the compartment? I know I will need to drain the fluid..and it was time to do that anyway...but I see no help in using something to go fishing in the tank......
