TO 30 Spin On Kit
phil(va)
Anyone have recommendations for a good spin on oil filter kit for TO 30? This site has one, Steiner does not. Does the kit from this site work ok? Any others to recommend? Thanks.
In nearly every case, the (thick) canister type is completely serviceable. Also most rugged. Requires but little care in service and assembly. For example- Hold cover CENTERED on O ring square as you tighten bolt at reasonable torque, et cetera. Far from rocket science. "Newer/ car like" ain't always better or required. Ever maintain heavy Industrial, Marine, or Locomotive engines? Hope that helps, Mr. David! Rock On.
