MF 1085 hydraulic filter housing
Benartm80
Trying to replace the hydraulic filter and the cast 1” nut on the bottom of the housing broke off.
Thinking of switching to a spin on filter housing but not sure what specs I should look for. Any recommendations?
Thinking of switching to a spin on filter housing but not sure what specs I should look for. Any recommendations?View attachment 64805
You need to find the pressure rating, micron rating, flow rating, and if it has a bypass relief inside the housing for that MF filter you have, to start comparing other units that might replace it.
My 2 cents: wrap a big pipe wrench around the housing and take it off. If the cast canister survives removal, have a large automotive nut brazed onto the bottom to replace the broken nut.
I would Not replace the original set up. That filter housing will unscrew easily if taping lightly with a hammer in the threaded area while trying to spin it off.
Will keep trying to get that housing off. Drained the oil and it had a metallic shimmer to it. Trying to get the basic things taking care of to see if we can get the remotes back in sufficient working order.
It's just a filter Any hydraulic filter assembly would work no more than 12 gpm there
That filter housing is a dinosaur
