New here, great site.
Got a 1972 MF135 with diesel engine. Used the pto to do some topping for the first time in some years and realised the pto was always on in "ground" mode and won t switch into neutral or "engine", i.e., when running along in gear the pto turns and works the implement, but I can t turn it off by moving the lever to the middle position, nor get it to turn when stationary by moving the lever all the way back to "engine". It used to work because I ran a log splitter off it while stationary some time ago.
Following various threads on here I looked into the clutch compartment through the access hole under the bell housing and checked the clearance on the three 1/2" bolts - they are all the same at c.80 thou. But at least four of the springs are broken. The clutch pedal free play is correct. There is occasionally some grinding when going into gear. The clutch doesn t slip.
Questions:
1. Could the pto problem be caused by the broken springs?
2. Is it possible to replace the springs through the access hole, or will I have to split the tractor and replace the clutch?
3. If the pto problem is unlikely to be caused by the broken springs where else should I be looking?
Thank you.
Questions:
Thank you.
