MF 40 New pistons hitting valves!
Rebuilding a Perkins AD3.152 in my MF 40. New head, pistons, rings, rod bearings. #3 piston is hitting the exhaust valve and locks the engine. It's on a stand so no damage. I'm thinking take the pistons out and have the tops ground down a tad. Any thoughts on that?? Thanks in advance. I'll probably just go ahead and do it but thought I'd throw it in here, just in case. I have tried what little can be done and it's no use. I have to back off the lash adjuster all the way in order for the piston to travel past TDC. I'll check into where I got the pistons but the 3
#'s were correct for my model and upon inspection before they were installed, they seemed an identical match to my old pistons, so WTF!!! Gotta be the piston, huh?
If they all 3 have the same part number I'd say 1 was machined wrong (just because they are new doesn't mean they are good). Get a caliper, and get to measuring
Thank you. What I found is that all three pistons are 0.016 in. HIGHER than the block! I'm taking them to a machine shop and have the tops milled down. They all sit higher than the new sleeves I installed. Anyways, measure I did and thank you ptfarmer for your advice.
I have pictures of the gaps.
Slide the wrist pin into both old and new pistons, THEN see what the difference is. Perkins used to have some unfinished pistons available that the tops had to be machined, I wonder if you got some like that.
Someone deck the block
I don't see any signs that the block has been 'decked'. The sleeves have a land at the ytop that fits into a groove, so any decking would require that to be re-milled. Not likely. The head is new. Thank you for your input.
They are the same, as most AD3.152's are. The pistons came together in a set with the rebuild kit from England. I think the most likely scenario is that I ordered the wrong set due to the fact that the preceding letters in my serial number are missing so it's nearly impossible to know what I have and what fits it, other than trial and error, which so far has resulted in the wrong pistons. I took them to a machine shop to have the tops milled 0.018in to put them where they should be. Problem solved!.... almost. The machine shop called and said the first piston done was well over done at .025 instead of the 0.018 I requested. So, I ordered a new piston (their buy!) knowing that it is probably not the right one for my engine but that it can be machined. TAH DAH! It's science!
Interesting, in an automotive application I would have immediately rechecked camshaft timing. I milled the dome off a MF 65 gas piston for a guy he was just replacing one piston and could only get the high compression version. The other pistons were all flat top, I couldn't convince him having just one with a dome would be no issue. I used to blueprint Chevrolet 327s the difference in the length of factory rods is surprising, piston height is also an area where there was a difference. Even crank throws had a measurable difference.
