john in the highlands
A number of years ago, my hydraulic pump ground-up some metal "object" and it got pushed thru the hydraulic system and scored the lift cylinder and pistons along with most of the parts in the pump. I replaced the pump, lift cylinder and piston along with the piston rings. Cleaned out the hydraulic cavity and installed new fluid. I had taken off my front loader to replace it's seals so I started using the tractor without the loader and replaced the Ferguson double spool hydraulic control valve with a hydraulic cover cap. I was only cutting my fields with it at that time while I worked on rebuilding the MF 32 loader. Years passed by before the loader was reinstalled. The loader works fine and maintains it's position weather the tractor is running or not. The lift cylinder for the 3 point hitch however does not. It falls slowing weather the tractor is running or not. I removed the hydraulic cover a found the lift cylinder and it's corresponding piston and rings in excellent condition! Except for the fact to and the gaps in the piston rings were lined up. Correcting this problem only made a little difference. I did notice more dirt inside the hydraulic reservoir than I would have expected since I change the fluid yearly and the boots over the transmission shifters are also new and intact. The pump hasn't been running smoothly. I'm thinking the hydraulic valve seat might have some dirt on them, causing a rough movement of the hydraulics. Restoring the hydraulic control to the hydra-lever and the draft control lever by locking the external control lever in the intake position, both levers work as they should. The corresponding springs are set to 3 pounds pressure. However the lift arms still slowly loose pressure weather the tractor is running or not! All the seals in the double spool control valves have also been replaced! Standpipe o-rings and back-up washers are also new. So what am I missing, that's causing the loss in the lift arm pressure? Could the new looking rockshaft cylinder and piston not be snug enough? I still haven't addressed the rough pump flow issue. I'm getting tired taking off the hydraulic cover. I'm not getting any younger!
