All 1965-1975 3xxx series gas engines were 158 ci displacement according to my references.I know 4/1/68 was the changeover date but I guess they continued installing the older components until you used up the inventory
I had a 4/15/68 4000 gas with older vent hood sheet metal and 192 engine and a June 68 4000 gas with newer sheet metal and 192 gas engine
Still have both blocks
Interesting looking pistons. Do all the Ford three cylinder engines look that way? Tim D, any info you can share?
Thanks for the info. Surely not the same as the 960 four cylinder!Gas engines have a large bowl in the pistons to lower compression, the heads are flat like a diesel head, no combustion chambers
My feelings are that the early engines were designed to use gas and adapted to use diesel.Thanks for the info. Surely not the same as the 960 four cylinder!
Completely different enginesThanks for the info. Surely not the same as the 960 four cylinder!
The engines brought out in 1965 were designed to run on diesel and that design was adapted to burn gas.
Just my feelings.
Keith
Yes, along with the cylinder head and associated parts. Its due for a complete rebuild.Got it, thank you!
Lisle doesn't say anywhere how low it cuts so no way to know either way!
So you thinking bring both the bottom and the crank to a shop and machine it the best course of action?
