FarmerBlair
Hi, I recently bought a 4-cylinder gas Ford 4000 at auction. It is a select-o-speed and has 6volt system. It looks good, but had been sitting in storage indoors for years. The fuel was yellow, and engine oil was a nasty creamy caramel-colored mess, as was the oil in the air filter cup. I replaced all that, removed and cleaned the oil pan, etc. Tranny oil looked ok, but changed that as well, and adjusted the bands on the sos which works well.
The problem is with the engine. It runs fine for maybe a couple minutes at 800-1000 rpm, then slows and runs rough to almost stalling out for about 30-60 seconds, then picks up again and runs smoothly. It goes through this cycle continuously. It does this when driving the tractor at higher rpms as well. I've tried adjusting the carb with no improvement. The governor was out of adjustment so I fixed that, and gapped the points and plugs as needed. The points and plug wires are all new looking. Plugs are older and black with carbon but not terrible. I ran out the old fuel and put in fresh, and replaced the sediment bowl filter and seal which pretty much disintegrated.
Compression isn't great: 100-60-70-110 dry (in order of cylinders 1-2-3-4). Wet test raised it to 120-70-90-120. Going to try soaking the rings by adding SeaFoam to the cylinders for a few days to see if it makes a difference. But doesn't seem like that would explain the problem with the rough inconsistent engine cycling. Also, the engine always stumbles when giving it throttle. I spent a lot of time trying to adjust the carb, but doesn't help. I opened the bottom plug on the carb and fuel would freely flow out. The main needle adjust on the carb looks new. The idle adjust screw on the carb (not the idle speed screw) is old, with a little bit of fuel looking like it weeped out at some point during my trying to find a set point. Could a faulty coil be causing the rough running problem?
