Probably a dumb question but I'm stumped . '57 F40. 12v conversion to alternator. Entire fuel system redone including relined the gas tank. New carb from Amz. (Old one had a crack in the bowl). New fuel lines. New fuel bulb. I had some grounding issues causing starter solenoid intermittently to give a tink and then nothing would turn over. Fixed the grounding issue. Bypassed neutral safety (don't want it). Removed ammeter since it didn't work on 12v.
Now I'm not getting any spark when it turns over. It will crank all day long no problem. Thought maybe the coil was bad. No idea how old it was but it showed signs of being pretty old, so I replaced it with a new coil from Amz that had a resistor attached to it. When I turn key to 1st position and test the voltage at one end of the resistor I get 12.38 and almost 6v on the other side of the resister. I've pulled the center wire off the dist cap and held it 1/4" or closer to the block (or an any metal nearby) and it doesn't spark. I've inspected and even recrimped the end of the cable thinking maybe it was a bad cable. Still not getting any spark. 1.8ohm between + and neg posts of coil. 10k ohm from + post on coil to center of the coil (where the cable plugs into). What am I missing ? Maybe something inside the distributor is causing the problem? I feel like I've done a lot of just part swapping to no avail.
