My 1947 2N was running great after new carb, distributer, plugs and wires, coil, and cleaning out gas tank and filters. I have very good gas flow thru carb. I changed oil and added sea foam to fuel tank for winter and plugged in a battery maintainer.
My issue: I started up tractor, purred like a kitten for a couple minutes, then started running as if the tractor was running on half cylinders, after a minute or so it started purring like a kitten again then started running bad again. Same cycle! I pulled plugs and they are completely fouled. I will replace plugs to see what happens but my questions is how plugs fouled? I ran tractor off and on in summer and it ran beautiful. My tractor was converted to 12v system by previous owner. I've owned it less than a year, so my question is, can a voltage regulator cause my problem? How can I test my voltage regulator? I will be testing battery voltage with a tester while running tractor after I change the plugs today but I cant figure out why this suddenly happened. Any incites? Can it be the voltage regulator and how can I know for sure if it is? I'm not a certified mechanic and don't understand the connection between the voltage regulator and firing sequence but I'm open to advice. Does the voltage regulator feed constant voltage to distributer, points, etc.. ? As you can tell, im obviosly not a mechanic. Please advise! Thanks
