'52 8N, ignition switch literally fell apart. There's some kind of bracket that it's installed in, and while the switch looks ancient, it doesn't look like any of the replacement switches I've seen for these tractors. Guessing someone put an automotive style universal in it some time ago, but the bracket it's in also appears to be spot welded to the dashboard, and _looks_ like it's a factory piece. The switch appears to have a pair of mounting ears on it that are then screwed down to this bracket. If someone added this, they went through an awful lot of trouble to get an oddball ignition switch in there....
I know virtually any on/off switch would work here, and it doesn't need to be anything special (I put in an Autozone universal, zip tied in place, just to get the tractor moved again) but I'm curious if that's how all of these tractors are? Seems like installing the common switch sold for these tractors through this bracket would eventually cause the dash to get bent up a bit under the compression, or sit down in the hole deep enough that I wouldn't be able to get a key in it...
Tried to get a picture, but with the loader frame in the way, and it being dark, this was the best I could do, looking in from the gauge hole where the ammeter used to be.
