Working to get the basket case 630 running. It's been "changed over" from POS ground to NEG ground. A one wire alternator has been installed.
I have don't have any spark. The new coil says it's internally resistored. New coil, distributer cap, plugs, graphite core plug wires.
The power wire to the coil is hot when the ignition switch is "ON". The power wire is hooked to the "+" side of the coil. The "-" terminal is hooked the distributer.
When the ignition switch is ON, I have 12.5v at the "-" side of the coil, and to both sides of the points (when the points are closed).
Trying to figure out what's wrong.
How should the coil be hooked up? Hot wire to the + coil terminal? Or should the power wire be hooked to the "-" coil terminal?
If the power wire to the coil is right, I'll try a new condenser.
Any other suggestions?
