Greenfielrider
I really hope someone can help me and point me in the right direction:
I recently acquired a 1972 Cat D4D dozer, which I believe has a power shift. I was told that it had sat for 4 years in the field. Unfortunately, once I started working with it, it began to overheat severely. I'm not referring to any strenuous activity; this happens simply when driving in, for example, second or any other gear.
Now, the strange thing is that at idle or high idle, I can let it run for an hour or longer. It does slowly climb above the thermostat opening temperature (taking 45-60 minutes), and then the temperature basically stabilizes there. I didn't manage to overheat it when just high idling. I let it run for almost 2 hours with no issues.
However, once I drive it, it takes less than 10 minutes before it reaches the red zone on the temperature gauge. After a cold start, I may get about 20-30 minutes or so.
I checked the thermometer; it seems accurate. The red zone starts at around 210°F-215°F.
I also measured the entire system from top to bottom. Here are the readings from the infrared thermometer at operating temperature (regulator/thermostat open):
- Thermostat housing: 180°F
- Radiator inlet: 178°F
- Radiator outlet: 143°F
—> The radiator seems to be fine.
- Pump top/outlet: 180°F
- Pump bottom: 142°F
- Oil cooler in: 180°F
- Oil cooler out: 193°F
- Transmission oil in (not driven): 184°F
- Transmission oil out: 195°F
I also measured the pump pressure:
- Pump pressure cold: around 15psi
- Pump pressure warm: less than 10psi
Unfortunately, I only had a pressure gauge from a compression tester. It's hard to tell if it's 9psi or 5psi for the pressure when warm (180°F), but it drops significantly compared to when the thermostat is closed.
The thermostat is new.
A block test was negative (blue).
There are no bubbles in the radiator.
There is no oil in the coolant and no water in the oil.
No external coolant leaks.
Does anyone have an idea of what I could look for next or what could be causing this?
