Greetings,
I have had the loader off the tractor for about 3 years. Now I plan to use it, but after connecting it back up neither the bucket up/down or bucket curl will move. Here is what I have tried thus far; 1) Swap hoses between up/curl. 2) put a jack under the bucket up arms and applied pressure, then pushed the end of the quick connect, fluid came out and the cylinder did move slightly. 3) remove 2 of the quick connects from the tractor, then moved the control back and forth, there was flow from both ports.
4) I have triple checked that I don't have 2 hoses swapped and flow them from the control ports to the cylinder(s).
It has power steering and it works just fine. The 3pt works normally and I have tried the loader with the 3pt both up and down. The fluid has some water in it and I plan to change it out again. My thought was with loader on, I'd pull the cylinders and drain them the lines also. I have no idea where the water is coming from as changed the fluid and did not put the loader back on...and still got water. I have barn space open now so after I drain and flush it I'll keep it inside.
I have a pressure gauge on order and plan to test first at the quick connectors, then on the feed to the control valve...
Any ideas? Could all the cylinder seals went bad sitting there? I'm thinking that's not the case as the loader has not slumped all the way down. Could some relief valve in the control have failed?
Thanks in advance!
Thanks in advance!
