I've seen those engines go 5,000 hours without much additional work other than routine maintenance.
Which includes the head bolt and valve adjustment.
Have you verified your glow plugs are working correctly?
Search glow plugs for Mitsubishi L3E
I'm not sure which forum I posted that information on.
I posted a few different alternatives. I believe the Toro glow plugs I received were Champion CH10. But verify that.
Whatever glow plugs you get, call tech support and verify the glow plugs are self regulating / limiting.
Without removing the glow plugs, you can do a quick continuity test, with the glow plugs disconnected.
With one test lead on the nut and the other to ground.
You should have something like .04 ohms max. If you have a buzzer it'll be going off.
The proper way to test the glow plugs is to remove them and visually test them as described in the service manual.
I believe these are 20 second glow plugs. You hold the switch for up to 20 seconds.
Currently the glow plug controller on my 223D isn't working. It's located towards the front of the Injection Pump on the right side. I have power to the controller, but not to the glow plugs.
Is your lift pump working?
Have you changed the filter on the Bottom of the lift pump?
Not properly servicing the fuel filters will kill the lift pump and / or the injection pump.
Have you serviced the fuel filter? Or verified it's flowing freely?
Remove the line at the injection pump, turn the key to run and you should be getting fuel.
If not, do that. I use Baldwin filters there
And everywhere else, when I can find them.
I apologize for not posting more links.
Are you familiar with the Toro parts and manuals page?
Your model and serial numbers should be on a tag, left side frame.
The tag on the deck / hanger frame is for the deck
www.toro.com
