I'm working on a late 560 with d282. It sat in a barn for about 42 years without running or being moved. When we pulled it to the farm I had in in fifth gear and slowly let the clutch out and engine turned free and built oil pressure. Stop cable was out, didn't want to try start at this time. Tach shows 2500 hours and was working when pulling tractor. Front tire wear seems consistent with 2500 hours.
I have since cleaned fuel lines, return line, and new filters and fuel. Glow plugs are marginal, more on that later. I have good fuel flow to the pump. If a crack an injector line at the injector or the pump end, I get no fuel coming out. I would think that about 3500 psi would squirt a little bit even when cranking. What more can I do to check the pump and/or get it to pump short of sending it in?
I checked the glow plugs one at a time watching the meter and it went about a third of the way, goes all the way to the right with all hooked up. Took 3 of them out and hooked to a battery. None of them glowed red but did smoke and get warm after 10 seconds. I have a new set coming. Problem is 3 don"t want to come out. Very tight. I twisted the nut off of one of the 3 tight ones. Any suggestions short of pulling the injector? I think I will try a 3/8 fine nut brazed on. I am open to all ideas. Thanks. Brian
