Richard JH.
Gents,
This an ongoing battle LOL!
I fixed the gear lever operated switch, as it was badly burned and such.
Got it all cleaned up and the copper contacts are still proud of the bakelite housing and the disk is cleaned up and spring good.
Put it in and no contact when gear lever is pressed towards start. Tried moving switch forward, slots are all clean, no joy.
Read up here and John in UK said take filler cover off and try Gently moving selector. (Thank you John!)
In Neutral I can buzz the selector back and forward into reverse and start no bother, and when I do this I have contact in starter switch. but, when I try with gear shift, it runs into the shift guide for "Start" position.
Gear shift works fine in reverse and all the other gears.
My question;
How are the shifter guides attached to the gearbox cover?
Is it possible to move them a shade? a 1/16" would give me the clearance for the gear lever to move selector back into 'start. as it is, it only goes half way back.
That's If the guides Are attached to cover.
I do have a book ordered but it is still on its way.
Thank you for any help,
Richard.
My question;
Richard.
