Hi, I am currently reviving a non-op to30 that sat for 10 years. Currently redoing the wiring back to factory. I pulled out the shifter lever and access panel, loosened up all the rails since they seemed to be stuck. Now 3rd and 4th gear go into their slots but don't stay in, it is super loose and sloppy. 1st and 2nd lock in when shifting into them. Shifting to start seems to work, i feel the spring resistance but reverse does not seem to stay in either, feels super loose and the rail easily moves back into neutral. This is all done without the tractor turned on. I did take out the springs right at the top, I don't really know what they do. Is the spring suppose to push down a pin to lock the rail to a gear? Thanks in advance.
