I don't know much about engine mechanics, kinda do it myself handyman. I've learned alot on this forum and reaching out to the tractor masters. My tractor is a 1947 Ford 2N, 12v conversion. I've owned it less than a year and think I may have stuck valves. I will be conducting a compression test when my tool arrives but all indications show a stuck valve. Missfiring continously after start up until it eventually dies during idle or adding throttle. This is my 3rd topic on the issue so please bare with me.
The question: can I spray a couple blasts of PB blaster in each cylinder for a preventative maintenance on the valves just in case they are sticking? I got the idea on youtube from a mechanic that was successful with this process. He had one valve sticking on him occasionally with same symptoms I had and sprayed the valve that was sticking on a couple different occurances until the valve eventually lubricated to the point it did not stick any more. Until I can tear into this engine for the long haul, a rebuild so to speak in the summer, would this process hurt anything eternally in the engine? It would be a heck of alot easier to spray a couple shots of PB blaster instead of removing the hood. Saying all this, I haven't confirmed my compression yet, I would like to get a jump on things just in case it drops a foot of snow tonight. Never know! I'm more or less looking for a mechanics blessing. Should I or shouldn't I? Any other short intern tips? Would it hurt to spray the valves if they are already in good shape? My gut tells me I have a valve sticking. According to the previous owner, the engine was rebuilt so I'm hoping I don't have a gasket leak, i haven't gotten to that point yet. The engine was running great at the end of fall until colder weather set in. Started missfiring consistently. Weak fire, steady solid white spark on all cylinders. I've went through some extensive ignition and carb checks to confirm those parts are operating correctly. Based on the 2 previous post.
This post was edited by Dwd14329 on 12/27/2023 at 05:37 am.
