I have a mid 80s Ford 1710 with the uncommon shibaura 3cylinder diesel. It has always used some coolant but this past weekend the headgasket finally completely went and was putting so much water into one of the cylinders that it would no longer fire. I pulled the head and was planning on getting it resurfaced but now I’m questioning if that’s possible. At the bottom of the injector hole there is a cone shaped feature with 4 holes in it. That cone is almost perfectly flush with the surface of the head. If the head gets surfaced it is going to shave that cone and the hole coming out of it down. It doesn’t look removable from what I can see. It also looks like the head may have been surfaced before as there is a plug next to one of the exhaust valves that I’m guessing was put in to address a crack. My experience has always been with gas motors so not sure if this cone shaped feature is normal on a diesel or if it is something that can be worked around when surfacing the head. A replacement head is out of the question as they are almost impossible to find and when you do they cost about what the tractor is worth. I attached a picture to try and help clarify what I’m talking about with the cone. Has anyone else run into something similar? Any suggestions? Do these heads typically warp or is it with risking the $100 and just slapping a new head gasket on?
