Wildcat4250
I have a 86 Puma 1000 with 4900 hours that has been well maintained with transmissions shifting issues. It has a 12 speed skip shift. Tractor has been jumping out of 3rd n 7th while under a load or not...basically transmission goes into neutral. It also likes to act weird n jump outta gear in 1,2,8,9 but it's intermittent. I haven't had any problem in 4,5,6,10,11,12. Transmission also likes to just randomly shift up on its own in the lower ranger gears...so be driving in 3rd n it shifts up on its own to 4th...it will shift up on its own in reverse too so I'll be backing up in reverse 1 n it just shifts into reverse 2 on its own. It throws a E50 code which I completely checked out. I replaced MPH n RPM sensors, replaced clutch cable, adjust clutch numerous times, disassembled spool value on front of transmission housing n cleaned, adjusted reed switch by clutch pedal. Transmission also shifts really hard from 6 to 7. The skip shift seems to be working right. It seems like something electric but not sure what. Any help would be great! Thanks
