Pulled the gear out of the "new" roller. It's pristine, and I don't want to put it in a severely worn geartrain.
Gear was removed from the broken roller for reuse. It was impossible to remove the bearing because it had rusted solid in the gear bore.
Bearing was cut out, cleaned, and inside bore mic'd to determine if it's too worn to reuse.
The bore is within .001 of the bearing OD, so it's good to reuse.
Bearings are inbound. A good quality National for the right side, and a lesser quality Dura Roll for the left side(I just need it to get through the season....the geartrain will require a rebuild this Winter)
I'm trying to decide where to order new belts from. The old ones are as slick as a banana, and the lacing is shot.
These came from the factory with Mini Rough Top belts, so that's what's going back in.
Every seller claims to have USA made belts. One seller is proud that he doesn't sell WCCO belts, which are American made. I have no idea who makes acceptable belts.
Thickness is another question. The belts range from .230 to .285, with the thickest being .315 I'm leaning towards the thin belts.
Two types of lacing are available. Clipper, and Mato. These balers came from the factory with Clipper laces. I also read somewhere(forget where), that the small diameter rollers on these balers don't like the Mato laces...........dunno.
I do know that I'd like to be able to replace the pins regularly. The pins in the old belts had worn into the clips, and had to be cut out. Dunno which style of lacing is easier to replace pins, but I suspect the Mato are easier.
I'm not at all familiar with belt balers. I've run an 846 for over 20 years. I actually think it's more reliable maintenance wise, and does a better job of baling a wider variety of crops. But.....the belt baler does make some nice tight bales, and hopefully will start a bale better with the new belts.
