Hello all!
Im new to this forum,
So I recently purchased a MF35 Diesel Deluxe that seems to be in pretty good shape with the exceptions of a few little gremlins. The previous owner had stated it was very hard to start and most times required a shot of ether.
I noticed that the ignition switch had been changed out and it no longer had the Ignition switch for the Heater start. After looking at how the Heater start is supposed to work and reading the manual, It appears that when you turn the key counter clockwise to the Heater Start position, it releases fuel into the intake manifold and the Coil ignites the fuel that provides the warm air when you turn the key on to the regular start position.
Is this correct????
Just kinda starting with the basics here so hopefully I can see this old thing run one day with everything corrected.
Any info would be greatly appreciated and Im thankful that I found a forum that covers these old tractors!
Is this correct????
