MF in Canada
Hello friends,
My MF 245 diesel (Perkins 3 cylinder) clicks loudly when I turn the key, but won't turn over or start.
I tested the battery with a load tester, and it showed weak, so as it was over 10 years old I replaced it. The problem remained the same.
The starter motor was rebuilt about 5 years ago by an excellent shop. And if I short the solenoid with a screwdriver, the tractor starts right up.
Does that mean the starter and solenoid are OK? And that I have a bad key/switch, or possibly a problem with the wiring from the key to the solenoid? It passes through the neutral switch on the transmission en route to the solenoid.
I don't understand why the solenoid would work when shorted and just "click" when activated by using the switch. Not enough amperage getting through a bad connection somewhere between the key and the solenoid?
Thanks for any suggestions on how to trace this problem.
Eric
Eric
