Acquired about a 2016 or so mower with a 22 HP BS, Hydrostatic, and 46" dual blade mower deck with 106 hours. I have an older mower of the same except the engine is a 20 HP BS twin (replace the original Kohler 20 hp single) Hydro., and very smooth pedal operation.
The transmission works fine and propels the machine much faster than the older one....not that speed is of interest to me but the problem is that if the engine is up around midrange or higher RPM, unlike the older one where pedal operation is smooth, this one goes from no drive to pop your neck drive with slight pedal movement once you hit a certain depression point.
Question is, is there any adjustment on the pump whereby you can slow down the response time and smooth out the engagement rather than having a "step function" in the ground movement?
