Gene Davis(Ga.)
- Location
- Middle Georgia.
Only thing I would say is don't get one with a on off switch and battery in it that can be replaced. To often you forget to turn it on or the switch goes bad or the battery dies. I buy the cheapest I can find.under $50 have used 4 in the last 30 years. first one lasted 15-18 years and was the best. I kept buying the exact same brand and model but the quality went down and the price up. But that is life.View attachment 930 Question, I am looking for a new hood. So after many years I have decided to get an autodarkening one. Anybody know about this one, it is the Hobart inventor series with the large lens and is at Tractor Supply priced at $129.95, what are the good the bad and the ugly things about it? Thanks for your time, and it is tractor related because I need it to do some welding on my implements. Gene Davis Tennille, Ga.
I think I know what happened to OLD. It happened to me as well with an auto shield. The flash comes in under the helmet or bounces off a bright white shirt you wear. I had nice new white walls in my building and welded for 4-6 hours. The flash off the wall came in around the back side and I got real welding flash BAD. had nothing to do with auto shieldI don’t believe you, and I’ve never believed your claims on this subject. From the beginning, AD hoods have blocked UV rays whether on or off, and that’s what causes arc flash: basically a severe sunburn to your eyes. It’s not the switching speed or the sensitivity. When you spout this BS, it causes people to steer away from technology that can really help them do a better job welding, and that’s a shame. if I recall, your version of the story is you were flashed working in an aluminum boat factory. Were you wearing safety glasses 100% of the time?
Frankly it isn't significantly bigger/better/nicer than the $39.99 one from Harbor Freight. If I was going to spend big money on one, I'd get the Vulcan one from Harbor Freight when it comes on sale. For the same money you get a much larger viewing space. Thing is the cheap Harbor Freight one has just as much viewing space as a traditional fixed shade helmet...View attachment 930 Question, I am looking for a new hood. So after many years I have decided to get an autodarkening one. Anybody know about this one, it is the Hobart inventor series with the large lens and is at Tractor Supply priced at $129.95, what are the good the bad and the ugly things about it? Thanks for your time, and it is tractor related because I need it to do some welding on my implements. Gene Davis Tennille, Ga.
The only option in that case is a pancake. Or curtains.I think I know what happened to OLD. It happened to me as well with an auto shield. The flash comes in under the helmet or bounces off a bright white shirt you wear. I had nice new white walls in my building and welded for 4-6 hours. The flash off the wall came in around the back side and I got real welding flash BAD. had nothing to do with auto shield
I went from not being able to weld at all to being a passable farm welder with an auto darkening helmet. When I went to lower the fixed shade helmet and strike an arc, the electrode would move and not be anywhere near where it needed to be.
BTW, the "solar panel" is not to charge the battery. That's the flash sensor that causes the helmet to darken, so don't leave the helmet in the sun thinking you're "charging the battery." You aren't. If anything you're running the battery down.
That's NOT always true! I dunno about the helmet the O.P. is looking at but there ARE ''solar'' recharging helmets out there.BTW, the "solar panel" is not to charge the battery."
I'd take that description with a grain of salt considering the source. Those helmets come in a plain white box with no documentation. That whole description is probably made up. The person writing it saw the "solar panel" and made the same mistake many people do. Heck for the longest time I thought they were "solar powered" until I learned otherwise."
ONE example...
https://www.amazon.com/Powered-Welding-Darkening-Professional-Adjustable/dp/B06XFSCDX9?th=1
''LONG BATTERY LIFE — This solar power auto darkening welding helmet is battery powered, but is fitted with solar panel technology to allow for effortless charging. Simply place your welding helmet within a naturally lit environment when not in use so it’s ready to go when you are. ''
Here's what the package for my Hobart hood (a different series than what the O.P. is looking at has to say about the subject..I'd take that description with a grain of salt considering the source. Those helmets come in a plain white box with no documentation. That whole description is probably made up. The person writing it saw the "solar panel" and made the same mistake many people do. Heck for the longest time I thought they were "solar powered" until I learned otherwise.
Look on the Internet there is one called true color and I can see a lot better with it there around $70View attachment 930 Question, I am looking for a new hood. So after many years I have decided to get an autodarkening one. Anybody know about this one, it is the Hobart inventor series with the large lens and is at Tractor Supply priced at $129.95, what are the good the bad and the ugly things about it? Thanks for your time, and it is tractor related because I need it to do some welding on my implements. Gene Davis Tennille, Ga.
I just bought myself an auto darkening hood. I read reviews by a guy called weld guru. He offered his opinion on about 9 or 10 helmets. I chose a Lincoln Viking 3350 from Amazon. It was on sale (and still is). I spent more than I originally wanted, but decided I'm old, and won't need another. I tried it yesterday and really liked it-just need to get all the adjustments down. Mark.View attachment 930 Question, I am looking for a new hood. So after many years I have decided to get an autodarkening one. Anybody know about this one, it is the Hobart inventor series with the large lens and is at Tractor Supply priced at $129.95, what are the good the bad and the ugly things about it? Thanks for your time, and it is tractor related because I need it to do some welding on my implements. Gene Davis Tennille, Ga.
