A quick question on remote hydraulics.
I own 2 Ford 851’s. One has a huge heavy 8.5’ custom plow on the front that has two lines coming out of the top of the trans case. It gets fluid through the relief valve ONLY when I max out the 3pt hitch and has a set of spool valves for raise lower/angle..
My other 851 has the (Ford I guess) squarish single spool valve sitting on top of the case with nothing plugged into the ports. I wish to purchase the Dearborn Blade Snow Plow & Model 19-80 Frame series and run the front Piston off this spool valve.
Here is the question: Is this setup independent of the 3pt OR does it run off the relief valve 3pt like my other tractor? When the hitch is down or ANY position, if I move the spool lever I hear a strain so to the novice mechanic like me it sounds independent but that could just be something else I don't understand.
Many thanks to the Board here. You are very good to an aging man.
