Hey guy's, my hunt club owns a Ford 3000 diesel tractor that has been used and neglected. I am the chosen one that has the task of getting it running again.
To start off with it had a leaking fuel shut off valve. I replaced it along with the fuel and oil change. Once done I noticed it still had a leak somewhere that turned out to be a pin hole in the fuel tank. When I changed the fuel filter, I noticed it had some water and rust in the old one and figured I would just run it then change it again after 4 or 5 hours run time.
I blead the system and got it running and it seemed to run ok for about 30 minutes then shut down. It seemed like it just ran out of fuel so I blead the system again and started it back up but would do the same thing again. I loaded it on the trailer and brought it to my shop. When I changed the fuel filter I drained and flushed the fuel tank before I blead the system with hopes of keeping any water and rust out of the fuel lines but now I'm thinking something had already passed through and has stopped something up down line hopefully not the injection pump itself.
I was thinking since I had the hood off anyway, I would change the fuel lines going to and from the pump and possibly the injectors also.
I hate to think about it but I suspect the pump itself is bad, but I don't have any way to check it. My shop burned down last Dec. along with every tool I ever had, and I haven't had time or the money to replace most of what I lost. My insurance co has been really slow but they are finally turning loose a little money here and there so I'm starting to replace some of the things I need to do basic stuff. I'm ordering a service manual off this site and hopefully it will tell what tools I need to check the fuel system.
I'm hoping that someone can give mt a few tips on replacing the fuel tank and checking the fuel system while I'm waiting to get my manual.
