Hi. I have a 1974 Ford gas tractor that I purchased recently. The first time I ran it it started missing and died after about 20 minutes. I started with the easier things and replaced the points and condenser, rebuilt the carb, replaced the shutoff valve and still had same issue. Would start and run for a bit and then start missing and die. Wait a couple of hours and it would fire up again and do the same thing. Next step was to remove the loader to access the fuel pump and replace it. After replacing the fuel pump it ran great for a few days but has started missing again...almost like it is fuel starved. Have checked fuel flow from fuel pump and appears to be good. I'm new at this and would appreciate any advice.
