Hello folks,
I find myself stymied by a problem with the hydraulic lift for my haybine. I'm hoping someone can enlighten me.
I used the haybine with no problems last fall, and this year when I went to start cutting I couldn't get the thing to lift up at all. I was using a different tractor than normal, so I tested out another tractor's hydraulics- same problem (and my hydraulics work for the loader on the tractor and the swing arm cylinder with no problems). No leaks anywhere that I can see. Fluid level in tractor is ok.
I checked to make sure there was oil at the cylinder- yep. Maybe I had a bad hydraulic hose? I swapped out for a new hose- now the left side would go up pretty well, but the right side (the "slave") won't lift at all. I then decided to test each cylinder in isolation- I hooked up the tractor to each cylinder alone and both cylinders will lift just fine in that configuration. I took the supply line off the slave cylinder and activated the hydraulics- seems like a pretty pitiful flow, a quick quirt and then nothing for a second, then just a trickle. Bad hose between the two cylinders? Nope, same problem when I take the supply hose off the bottom of the master cylinder.
Then I thought there was something wrong/clogged inside the master cylinder. I dissassembled it, no obvious crud or debris, no rust or broken parts. I blew air through the exit crack around the push shaft, seems to come through to the exit port with no issue.
For the heck of it, I dissassembled the slave cylinder to have a look as well- nothing wrong that I can tell.
I then replaced the hose between the master and slave just to see if it made any difference- no luck.
It does seem like I have air trapped in my cylinders, but I just bled the lines and I got the slave to rise once veeeery slowly, but since then, I can't get the right side up more than a few inches, while the left side comes right up.
So basically, I have poor or intermittent hydraulic pressure at the point where the master cylinder supplies the slave. What am I missing here?
Thanks for any ideas!
Ben
Ben
