Just wanted to let you guys know the A is now starting and running great. Even after cleaning the carb thoroughly it still was not starting the best. The spark seemed to be getting weaker too. I had this same issue with the F-12 and had to get a new coil.
Sure enough got my new coil installed last night from Brillman and the A started on the 3rd crank. Picks up in 4th gear no problem, and runs strong. Shut it off and started it back up with 2 cranks - no choke.
Thanks for all of the help. Now I just need to get a new hub and change out the other tire and it'll be done.
