Tall T
When I first back the Jubilee out of its shed, the very first movement causes a very audible "clank" sound from the left rear as though that axle was stuck somehow with sitting and then breaks free. After that it barely makes the sound a couple of times backing up, then no more. It seems to be connected to sitting for a couple of days. (?)
It's not a deep pitched clunk like I'd expect from deep within the heavy housing but more like it could be brake rod or stuck shoes letting go or something. That side is leaking lube badly and the brakes on that side have never really worked as a result of being wet. I have all the new parts, but not a new hub.
If it was a hub, I'd expect it to keep on doing it with every forward and backward movement, but it doesn't.
I noticed my PTO shaft area isn't wet with oil and wonder if being seriously low on gear lube could have something to do with the sound.
Any thoughts/
T
Any thoughts/
T
