Hobbyfarmer 52
Grandpas 9N has been sitting in a shed for 8 - 10 years and when the shed started to fall down it was pulled outside for the last year. I brought it home and thought i would try to get it going. It’s an older 9N with the starter switch in the dash but it does have an 8N engine in it with the side distributor. I drained all the fluids and replaced, cleaned the carb, filed the points, hung a temporary gas tank on it and put in a battery. It didn’t crank much before started and it ran pretty good. Now the next thing to work on is the 3 point. The arms make no attempt to raise with PTO on and moving the lift lever. There is some movement on the top link spring. Reading posts i could find it looks like my next move is to remove side covers and see what’s happening inside with oil. Does anyone have any trouble shooting tips for this situation? The tires hold air for a while but are pretty rotten so i would like to see if the 3 point will work before I invest in tires which are probably worth more than the tractor. If it wasn’t grandpas i probably wouldn’t be messing with it.
Thanks for your help,
DJ
DJ
