Neighbor has a 335 Case IH steiger that has a cooling issue. When the tractor is in the field working it runs cool NO issues. But when you slow the tractor to an idle
it shuts off due to over-heating.
The tractor was purchased new and is in excellent shape. Belts are tight and NEW good, fluid levels are good. Screens and radiator are not plugged. There are NO
visual reason for this problem.
The 335 CIH steiger does use a clutch fan. The fan turns at idle.
I was looking in the messick parts books for a part number thinking the clutch fan may be the problem since the tractor only gets hot idling; but I can not find a
listing for the clutch fan for the 335 Case IH Steiger.
Any thoughts on what the problem could be. This is a well cared for Low Hour tractor
