Sorry wore out. The tractor never had an air intake or air cleaner when I bot it probably cause someone else changed the motors. I ended up making an intake using 2" pvc and it was made with a uturn in it cause I ended up buying a Donaldson truck air cleaner and if I mounted it on the front then I couldn't see the loader so I mounted it on back by the gas tank. Not long after that is when I decided to tear it down to work on which was about 15 years ago. I'd still like to find the old style air intake with dust bowl as they don't take much room to block the view of the bucket.
When I bot the tractor it had a 12 volt system with voltage regulator. With the help of the members of this board I converted over to the Delco Remy alternator from NAPA everyone recommended along with a new coil. The 10 gauge wire goes directly to the ammeter. I think this is the one wire type. It does have a bolt on the back on the right side
View attachment 66650View attachment 66651 which had me wondering if there was a ground wire coming from it. I took a pic of that.
I have CIH wiring diagrams for a 606 and 660 showing the coil wire going down to the hot post on the starter which has another wire that goes back to the key switch. That is how I ran it and when I pulled the engine I just laid the coil on the starter and didn't mess with any of that wiring.
I checked the throttle to governor linkage. On the dash on this tractor it shows Lo with the throttle handle in the up position and then you have to pull it down to increase the throttle. Handle in the up position and the throttle is closed and handle down it is open so that appears correct. Got a pic of that.
