rlp in Co.
I just got this truck running and have taken it for a couple of test drives. The problem is, it is very hard to shift because the engine is very slow to idle down. Sometimes the truck slows down faster then the engine and you have to go back in the lower gear. At first I put an extra spring on the fuel pump but that was not the problem. It must be something wrong inside the fuel pump. Tomorrow I'm going to put a fuel pressure gauge on it and see if the fuel pressure is slow to come down. Has anyone heard of this problem before and knows what is wrong?
It is a cummins 335 HP, small cam engine. It has high flow injectors that takes it to 575 HP.
