Whistlin10Speed
I have a 1953 Ford NAA Jubilee that is in great shape for It’s age. It has plenty of power and runs like a scalded dog…. Until today.
I went out to bush hog and cut for about an hour with no issues, then it started to stumble under load and die. It would fire right back up each time but after heating back up it would stumble and die again. This happened 3 times or so before I got fed up.
I had a new carburetor for it (Amazon cheap model) so I swapped it out, and it fired right up but immediately was wide open max RPM, so I took the old one apart, cleaned it and put the top of the old on with the bottom of the new one, same issue. I put the old one back together and put it back on, and still it runs wide open like it’s going to the moon immediately after starting.
I adjusted and adjusted and adjusted and it would either not start or run wide open immediately upon start up.
The throttle lever doesn’t change anything, am I missing something?
The only thing I touched was the carburetor, the choke, and throttle cable.
Is there a governor or something I may have screwed up unknowingly?
Anyone else had this problem or have any ideas?
