Gentlemen, a couple of you on here have gone through the rebuilds in these engines pretty thoroughly. Have any one of you taken the time to determine the piston position down the wall at 8*. I may be in a situation where that info would be helpful. I know it is an unusual request but hoping! My own 530 had an engine replaced and it was from a crawler which had the timing marks in a hole up right behind the starter and they did not change the flywheel so I have no timing references and I am involved with a 630 with a similar issue. I guess that's what happens when you get called in on the end of these projects.
