14,000 lb equipment trailer jack issue
michford
Location
Michigan
Having an issue with the drop foot jack on my equipment trailer. With no load on the jack, the jack runs up and down. As soon as there is a load on it, the jack will not lift. I opened the small square top cover, and the bevel gears are engaged on the 90 degree shafts between the handle and the vertical jack. Anyone ever ran into this, and if so what is the fix? Or is it just as much to fix as replace the whole jack? Equipment trailer is a Big Tex 14K.
20240305_203836-jpg.61369
Will not lift as in the handle turns, but the leg doesn't move? Or it won't because you can't turn the handle once the leg foot makes solid contact with the ground?
Can continue to turn the handle, jack just won't lift once it has a load on it. Without a load, the handle will run the jack up and down.
Many pin the gears to the shafts. Could be a pin that holds a gear to a shaft has sheared. It may catch and drag enough to move the leg when there is no load on the leg.
pin or key sheared and they need greased often like a few times per year. I greased mine each time I greased the truck and trailer so about every weekend. Or 2500-3000miles. IT hardly ever was unhooked from the truck also.
Should be able to see down in and determine that the jack screw is turning inside the bevel gear. If the gear is spinning on the shaft you sheared that pin. If the shaft spins with the gear, you stripped out the jack nut.
Does the jack hold weight, or does it collapse? That's another indication. If it holds weight, pin. If it collapses, nut.
Great cross section. Watched a good youtube video, I'm betting the crosspin in the bottom of the bevel gear on the screw & nut assembly is the cuplrit as the jack holds weight.
rebuilding square tube jack
Removed jack from trailer and disassembled. The screw and nut appear to be the problem. The nut will slide up and down the threads of the shaft. I have a replacement shaft and nut assembly on order from etrailer.com will update next week when replacement gets installed into jack.
Probably would have been cheaper to go to junkyard and get one off from and old semi trailer and would probably out last your trailer. I've got some on a trailer that was built in 1998 still work with no issue never been apart. Sounds like your jack is not built heavy enough for the job.
I don't doubt for a second that a square tube trailer jack built in the 90's or earlier will outlast anything built today, but I wouldn't even know where to begin searching for one off an old semi trailer. Even if I found one, I'd probably have to modify it to mount it to my trailer. Sounds like the jacks built today don't like to be run to the ends of their threads so I will keep that in mind when using after repairing. The parts from Etrailer set me back $105 with shipping so the cheap parts have a cheap price. If I have problems again, maybe I'll try to search out an old semi trailer jack and see if the internals would fit inside my jack. Thanks for the idea either way about a semi trailer jack caterpillar guy!
Parts came in a day early from etrailer so I got busy and put it all back together. Works great, hope I get more than 7 years out of this screw assembly.
