Merry Christmas, everyone! Was hoping to get some thoughts on what to do while I have a few days off.
Trying to get the wiring system charging for the first time in decades. Following "John T s Trouble Shoot procedures" on yesterdays tractors. Last Thanksgiving I dragged this tractor out of a wood line.
12 v Gen , Voltage Regulator system with a Magneto (separate). Mag has independent on/off switch works great!
Gen "motors" just fine but instead of speeding up when removing Field wire the motoring stops leading me to believe F is bad on generator. Just placed a New VR 12 v on this tractor.
My ammeter is not reading anything when checking with a volt meter, not positive or negative when running tractor just at 0. do I have it wired incorrectly?
From Generator to VR: F to F. A (armature) to Arm or Gen on VR. Ground on Gen to Ground on VR.
From VR : Bat terminal to - side of ammeter and + side of ammeter runs to the starter.
Bat Terminal and Gr on VR read 12.8 - 13 or more when rpm s high on running tractor.
+ and - ammeter terminals read 6 volts or under and not changing anything on the gauge.
Battery consistently reading at 12.1-12.3 v and never more than 12.30 v.
New VR that is polarized touching Bat and Arm terminals with a spark. all new wiring everywhere. I m a novice so wiring isn t the best you would see but it s all new. No light setup yet.
Ammeter was tested by me with a AA Battery and moved the needle just fine. It s original to a 6volt system mid year Farmall A.
All wire is 12 Ga. I performed a mechanical restoration and wanted this to be able to charge plus add lights. I can t find ANYTHING with a 12v and Mag. Please, help. Thank you all.
