I have only fixed one for what's its worth I went by the rod size. The best I remember there are two sizes, 1/2" and 5'8" (.625)
That is a after market cyl. there is various mfgs of them.
It will probably be easier to take it to a local hydraulics shop and let them source the parts. If you want to save the cost of labor, dismantle it yourself and just take the seals to them and let them find replacements. Personally, I would pay them to dismantle it, get the parts and rebuild it. I never seem to have enough time to do all of the things that I would like to do these days.
There is nutting to repairing them you don't have to take it off the tractor. The hard part you can damage one of the seals when you slide it over the threaded part make a sleeve for the seal to pass over. I made a post on this but YT has not revived the archives. Whut size is the shaft???? a couple part numbers to look at. S.60688 and S.60666. The one I built. Worst case take it apart and match it to the numbers I posted.
Thanks, I appreciate the input. The shaft measures just over 1/2", I have rebuilt cylinders in the past but was hoping to order parts and have them ready before disassembling.
S.60666 for 1/2" rod is my best guess.
I found pix of the seal kit in mine it was S.60666, my wager the A&I is the same cylinder your call.Thanks for the links. I found the deal kit yesterday but I'm unsure on the manufacture as it indicates these only work A&I products. I as hoping to confirm before ordering any parts.
Thanks for the links. I found the deal kit yesterday but as sure on the manufacture as it indicates these only work A&I products. I as hoping to confirm before ordering any parts.
Ford Power Steering Cylinder Repair Kit for Ford 2000,230A,231,234,3000,335,3600,4600,531,601,611,621,631,641,651,661,671,681,801,811,821,841,851,861,871,881 - E2NN3A540SK
Power Steering Cylinder Repair Kit E2NN3A540SK for sale, For tractor models 2000, 230A, 231, 234, 3000, 335, 3600, 4600, 531, 601, 801. For Ford 2000,230A,231,234,3000,335,3600,4600,531,601,611,621,631,641,651,661,671,681,801,811,821,841,851,861,871,881 tractors. Item 115362www.yesterdaystractors.com
Fixed it so the verbiage doesn't include A + I.
ALSO, It works for your application.
Anyone have any reference material on rebuilding these cylinders? Looks like Hobo, NC had a thread at one time but it no longer is available. This is my first time rebuilding this style and want to make sure I don't screw it up. Thanks.
