I'm working on a 1980 Ford Industrial 445 tractor, diesel engine. Trying to figure out which diesel engine size I have. Been doing a lot of research on web on decoding model, engine, and date codes but need some help. I want to either get a new/reman cylinder head or take it to machine shop for rebuild, or do what i can myself with new valve train kit in my home shop. Problem I have is trying to decipher which engine size I have to get the right parts. Its a 3 cylinder diesel but Ford made several. I think I have a 175 or 183 but not sure. The head bolts are 1/2", round intake ports with rectangular exhaust ports. I will post all the codes I found on the tractor. There was no ID tag anywhere and the following numbers are all stamped in the castings.
Engine Casting Stamps: T6 D5NN6015F *K456776* also above engine stamp was a tag with 9G23 I think. Its very hard to read.
Tractor Codes behind starter: kd314k 0a24b *c637249*
I will post pics. So, I want to know what size engine I have so i can either buy correct cylinder head or buy a valve train kit. Or, Is there even a difference in the valve train kit between the different size 3 cylinder engines? I wouldn't think so, but I want to be sure. I know there is a difference between cylinder heads, some have 9/16 bolts and some have 1/2 bolts. According to Reliance Power Parts, there was a 175cid and a 183 cid made in 1980. Tractordata.com says the 445 came with the 183 cid. Just want to buy the right cylinder head or valve train kit for this engine. Any help or input would be appreciated.
