sandspider-HT
Hi folks
I was just wondering, what sort of temp differential is normal between top and bottom rad hoses? I ask as I had a bit of a blocked radiator with a leak, so flushed it all out and used a leak sealer in it. It runs fine, or seems to, but the bottom rad hose never gets very hot, lukewarm maybe, while the top rad hose is really hot to touch. I don't know if this is normal, and I didn't check the rad hose temperatures while it was running normally! I know this tractor is thermosyphon only, so presumably the bottom hose never gets too hot, but...?
On an unrelated note, am I right to assume that changing the fan belt means removing the rad hoses again, and the radiator shroud or the fan itself - there's no shortcut?
Thank you.
Thank you.
