Dan in North Houston
I've seen lots of posts on here about the problems with them on 4020's and others, and since I have a 4020, I figured I would have to do that fix sometime. As it turns out, I picked up a 3 cylinder 830 that needs new load shaft seals, so I guess the time has come to tackle that job. I've watched several videos showing people fixing them, it doesn't look too bad. Hydraulic oil and filters need changing, so it's a good time to take care of it.
But why does JD run the load shaft through the transmission housing in the first place? I thought maybe there was some linkages to the draft control, but I've reviewed the parts and service manual and that doesn't appear to be the case, at least for the 830. Is this just a JD thing? Having seals that are likely to need replacing several times over the working life of a tractor, in a place where they are going to dump gallons of hydraulic oil out whenever they fail doesn't seem like a good idea to me.
Any hints or cautions on the job are appreciated.
