Mad Farmer
- Location
- Northeast
You might find things of interest in this thread: https://forums.yesterdaystractors.com/threads/z-134-rocker-arm-lubrication.1696607/
Modern replacement valves do not use caps.
The pan is easy to remove, cleaning inside with diesel is a fine idea.
I was following/replied to that thread, and learned a bunch about Fergy rockers/valves there.
How do the rockers that were designed for valves with caps do without replacement caps? I'll be pulling the shaft apart next few days to see if it's useable for a while or if I'll be hunting a good used assy. If anyone has a good assy/shaft/rockers let me know.
I see the site here has a rocker arm bushing set, the bushings need to be fitted to the shaft. The shop manual mentions that the rocker tip surfaces that contact the valves can be reground by a machine shop. Has anyone here done/had done either of this work?
Presently I'm just trying to get the Fergy runable for use this year, I really need it. I'm working outside so trying to avoid too much taking apart. Not sure if I want to tackle taking off the pan and associated clean up of grunge (just the outside) to do so. That would let me do a proper cleanup inside. Would have to hunt down gaskets, or maybe just buy a whole gasket/seal kit.
I'll post some more pictures when I get the rocker assy taken apart
