Moving a tractor
gheise
How do I get an early 60’s Ford with a Select-O-Speed transmission to roll? It is not running and I need to load it on a trailer. I have tried to push it in gear, in neutral, park, clutch in, clutch out. All it does is rock back and forth. What am I doing wrong?
Behind your left foot when sitting on the tractor, there is a strap/lever that is the driveline disconect. It has a nut in the strap, BE SURE TO BLOCK THE WHEELS SO IT CAN'T ROLL!!!! Remove nut, flip the strap over and move the strap the other direction, this moves a sliding collar inside the case to let the tractor freely roll. REMEMBER PARK WILL NOT WORK UNTILL THIS PROCEDURE IS PUT BACK TO IT'S ORIGINAL POSITION!!!!
