M9540 + R14 Questions
Newtek
2007 M9540 with rear cast centers, standard fronts per the following:
420 / 85 R 34 Rear Rubber
320 / 85 R 24 Front Rubber
Has anyone else swapped to R14's on existing Wheels on the 9540?
Does anyone know or possibly have ordered a new set from Kubota with the cast weighted rears with R14 or only after?
Anyone know where or have a thought on where to find another set of cast rear centers same size? I still need my AG setup, & I have found the outer rims used, but I might simply keep 2 sets (1 R14 & 1 AG) to just swap as needed.
Anyways, appreciate any guidance. Maybe have to get normal rear wheels + R14 & then add weights. I may look to find a shop that can make the cast centers from what I have now if the price is right & then buy a set of used outers.
Update:
I currently have the Rear 34 \ Front 24 per below along with the Titan Wheels. The R14T Part#s Titan confirmed fit this setup.
I am now looking for another full set of 34\24 to have 2 full sets but 1 AG, 1 R14T in case anyone comes across these, please do PM me & thanks in advance.
420 / 85 R34 Rear Rubber | Wheel = Titan 34XDWW 15A 3 18 07 S2 _ 04 21273 00 187 | R14T = Part# R4T154
320 / 85 R24 Front Rubber | Wheel = Titan 24XW10 129 _ 03 10 8 03 06 S1 | R14T = Part# R4T214GEF
Center is 6" studs 8"
Have to go to his yard and see if there is one more also sure there is but need to check
